bomm vang
bomm vang
Postby Roger » Fri May 16, 2003 6:27 pm
Any body have a picture of how their boom vang is set up? I have all the parts, except the piece that attaches to the mast, and not sure how to proceed. If you don't have a picture, I sure would appreciate a good verbal discription.
Postby Guest » Sat May 17, 2003 7:03 pm
Roger -
Assuming you have a DS1.
You should have a bail that is on the mast just above the mast partners (where the mast goes through the cuddy).
I then just use a twist shackle (or a straight will work, depending on the block you use), to attach the vang to the bail.
Let me know if you have any further questions.
Don
Don Trop (don.trop-at-att.net)
Postby Roger » Sun May 18, 2003 12:24 am
I have a DS 2, but that gives me sufficient information regarding placement. Thanks.
Postby Guest » Mon May 26, 2003 12:29 pm
Hey Roger, I just bought a 15:1 Dingy Vang from APS to use on my DS1. It's nice but kind of expensive. I think it's a Harken H447. You can find it on the Harken website is you want to check it out.
Jeff
Jeff Smith (jsmithhouse-at-core.com)
Postby Roger » Mon May 26, 2003 10:10 pm
Wow! 15:1 You should really be able to bend that spar out of shape if you wanted to. I installed a 3:1 on the weekend, and will give it a try soon. I have to paint a hull first.
Users browsing this forum: Google [Bot] and 7 guests
