rigging jib sheets
rigging jib sheets
Postby Guest » Wed Sep 24, 2003 10:47 pm
I just came into possesion of a 1967 DS1, and am new to sailing. I have all the rigging right, I think, but one question. When I got the boat (from someone who sailed her for 20 years), the jib sheets were rigged outside the mast stays. Should they be inside the mast stays? I took her out the other day and had trouble getting the jib set right, after moving them inside the stays.
Steve Bergstrom (starfish-at-cox.net)
Postby Guest » Wed Sep 24, 2003 10:54 pm
Inside the stays. On a larger boat the jibsheets are usually run outside the sidestays, but the small O'Days run them inside the stays.
Rod Johnson (daysailermanual-at-juno.com)
Postby Guest » Thu Sep 25, 2003 2:33 pm
Run the sheets inside the shrouds. A neat trick for singlehanding: tie the ends together so
you don't lose the lee side in the bottom of the boat when you tack, just tug on the one
continuous jib sheet.
Peter Tenerowicz (peteten-at-hotmail.com)
