ChrisB wrote:Scott,
I would leave the sock on the jib and the cover on the main until the first sail of the weekend and then not worry about re-covering the jib. The bird forces your hand on covering the mainsail.
Chris
TIM WEBB wrote:With parachutes, the canopy portion is almost always Nylon, with very few exceptions. Lines are usually Spectra, Dacron, Vectran, or Kevlar, while containers (the "backpack") are usually Cordura or Parapack (Nylons). The latter can be treated with UV protection, whereas the canopy/lines cannot, but the container also tends to see more sun exposure (walking around the DZ, waiting in the boarding area, etc). Harnesses are made of Nylon webbing, but they are required by the FAA to be like 10 times stronger than they need to be (and drop tested to prove it!), so loss of strength there isn't really ever an issue. It's usually abrasion or damage from acid or whatever that does a harness in ...![]()
For sails, perhaps a better comparison would be between, say, Dacron mains and jibs, and Nylon spinnakers/headsails?
Breakin Wind wrote:Next thing ya know, I'll want to have the boat already untied and ready to push of as I walk from the cabin to the dock so I can just step on and go...
For that, I would need a dock boy? Wouldn't that get the neighbors talking...
GreenLake wrote:I know standard sailcloth uses fillers, mainly to make the cloth stiffer; presumably they also add to the UV resistance, but I couldn't find anything definite on that. For laminate sails, they definitely add coatings to reduce the effects of UV exposure on the fibers. I imagine none of that is done for parachutes.
