North Sails Code Zero
Postby Hesedguy » Mon Aug 11, 2025 1:04 am
I bought a Code Zero from North Sails this summer and though it's only been out once I thought I'd give a report on it. Price was $600, so not bad after getting a $936 quote for a Doyle UPS. It's the Helix Cruising G-Zero specc'd to the Daysailer by the Portland, OR North Sails loft (Kerry Poe). I decided I wanted it to be run inside the fortriangle (like a jib) and about 71 sq.ft., same as several UPS on here. But it's made of 1.5oz Dacron, instead of Nylon.
I wanted it to be sheeted to blocks tethered to the rear cleats, and it came out perfect, creating a visibly better slot than the jib with the mainsail, not backwinding it when close hauled.
I took the sail out for the first time on Thursday and it was a blast! It is a LOT of sail, but it was designed perfectly for what I wanted. It is definitely meant for light air, even 8-9 knots it was overpowered. The Daysailer, however, handled my hard testing like a champ, and it was never scary like it can be with a traditional spinnaker, with my and a friend on the rail it just spun up into the wind and depowered. I was able to get about 55-60 degrees off the wind, and it HAULED. It was amazing how fast we were moving in the light evening air.
Definitely recommended for anyone looking for better light wind sailing.
Hesedguy
Re: North Sails Code Zero
Postby GreenLake » Mon Aug 11, 2025 8:37 am
Nice.
Return to Sails
