Swim Ladder?
Swim Ladder?
Postby Rakozy » Thu Aug 20, 2015 11:22 am
Anyone found a swim ladder/rescue ladder which works well with the DS II?
Rakozy
Rakozy
Re: Swim Ladder?
Postby GreenLake » Thu Aug 20, 2015 1:26 pm
jeadstx has fitted one he's happy with.
Re: Swim Ladder?
Postby jeadstx » Thu Aug 20, 2015 6:20 pm
I put a three rung extendable ladder on the stern of my boat. When not extended, it folds up against the transom. I hold in place with a bungee cord that can be released from outside of the boat if needed.
Re: Swim Ladder?
Postby TIM WEBB » Thu Aug 20, 2015 7:49 pm
I went with this one:
http://duckworksbbs.com/gear/ladder/bt-lad.htm
I hang it off a stern cleat, and I made a Sunbrella cover for it, basically a tube with one end closed and the other end with shock cord in it to hold it mostly closed. I put a loop of webbing on the bottom of the closed end to act as a handle to pull it off the ladder. It just sits on the seat near the cleat. First time out with it, I hove the boat to and over the side I went. Found it very easy to reach, pull the cover off with the handle, deploy the ladder, and climb back in. Does take a bit of balancing, but you really only need to get a foot on the bottom rung in order to hoist yourself up far enough to get a leg over the gunwale and climb in. Definitely not a worst case scenario test, but better than nothing ...
Re: Swim Ladder?
Postby Salty Dog » Thu Oct 22, 2015 10:20 pm
I used one of those ladders that hook over the transom. the standoffs were too low, so I moved them up. This works good for my boat.
SD
Salty Dog
Re: Swim Ladder?
Postby jeadstx » Fri Oct 23, 2015 2:03 pm
Attached is a picture of my ladder. I got the ladder from the Sailboat Shop in Austin, Texas.
Ladder in folded up position
Ladder - Folded up.jpg (63.05 KiB) Viewed 16074 times
Re: Swim Ladder?
Postby seasick » Thu Aug 11, 2016 7:21 pm
I went with a 3 rung sport/dive ladder from Overtons. Because of the way the seats are molded into the boat there did not seem to be enough room on the transom for the fold up ladder to be attached thru the inside of the boat. The dive ladder has a very small attachment.. a wedge about 5'x3" and the ladder can be detached and put in the boat. Not as good as the fold-up for safety ( I keep mine attached if I am out alone) but it's sturdy and angled, so it's easy to climb up.
seasick
Re: Swim Ladder?
Postby GreenLake » Thu Aug 11, 2016 8:27 pm
Not sure from your description which model you ended up selecting. Also, does the ladder extend into the water while you are under way? I see from a different post that you mostly motor while waiting for your mast. Dragging a ladder through the water is no fun when sailing.
Re: Swim Ladder?
Postby seasick » Fri Aug 12, 2016 11:40 pm
GreenLake wrote:Not sure from your description which model you ended up selecting. Also, does the ladder extend into the water while you are under way? I see from a different post that you mostly motor while waiting for your mast. Dragging a ladder through the water is no fun when sailing.
It says sport/dive ladder at overtons. Sorry I don't link. yes I do drag it while sailing alone. The boat is fast enough so I don't care. I cannot get back into the boat w/o it should I fall oveboard--so I don't care about the drag. I didn't appear to interfere much with handling--but I'm not too fussy yet. I get there and back --I'm good!
seasick
Re: Swim Ladder?
Postby GreenLake » Sat Aug 13, 2016 1:35 am
Linking something isn't that hard.
See: viewtopic.php?f=41&t=5346
You might also want to check out the topic on Partial Quotes in Replies
Re: Swim Ladder?
Postby jsbowman6 » Mon Aug 15, 2016 3:16 pm
Thanks jeadstx! This upgrade was easy. Hardest part was finding some deep throat clamps to hold the ladder while I checked that the rudder could swing fully, the top step was low enough for your foot to fit under the stern, but high enough so I didn't have to use an inspection port for the bolts. And again thanks jeadstx for making me aware of getting as close to centerline of the boat as possible so the boat would not be so tippey while using the ladder.
ladder up.jpg (86.88 KiB) Viewed 15829 times
Ladder down.jpg (94.67 KiB) Viewed 15829 times
jsbowman6
Re: Swim Ladder?
Postby jeadstx » Tue Aug 16, 2016 1:16 am
You're welcome.
Users browsing this forum: Google [Bot] and 6 guests
