DS 2 CB Rope Length?
Re: DS 2 CB Rope Length?
Postby KeithS » Mon Jun 03, 2013 7:44 pm
I almost forgot to answer the question about the hole in the CB. I did not enlarge the hole, because I did not want to damage the center board. I did stick a bent coat hanger wire in it, and determined there is a cavity up in there.
I think only time will tell if the downhaul line attachment to the center board holds up.
KeithS
Postby JediEMT » Mon Jul 29, 2013 5:51 pm
Keith,
On your CB the plates and wedges. Do you have a lot of play in them? We replaced the downhaul line two weeks ago by having to remove the CB. I noticed a lot of "slop" between the CB and the walls of the boat.
Mike Pierson
JediEMT
Postby KeithS » Mon Jul 29, 2013 9:45 pm
I do not remember noticing much slop or play between the center board and the hull. I replaced the downhaul line from under the boat on the trailer. The center board was resting on top of one of the rollers on the trailer.
KeithS
