What I was thinking was to take down the 3rd wheel on the trailer and put the bow down. Then putting an electric bilge pump in the bow tank bilge area and hosing out each seat tank. Being sure to keep a minimal amount of water in the bilge.
Basically I'm trying to use the water to float any remaining foam "balls" to the bow at which point i can get in there and shop vac them out. I figure this way I will keep the debris away from the transom drain plug.
I've had the full shop vac hose in each tank but i can't get my hand and the hose in there at the same time (4" ports) i got a good chunk of the junk that i could see out but there is still more.
As an aside...
Buoyancy is roughly equal to the amount of water displaced. So each 2L bottle will provide 4.2 to 4.5 LBs of buoyancy depending on which calculation you use. There is no way I took out 500LBS of positive buoyancy foam from the DSII was O'day betting there being some air trapped in the hull to keep the boat afloat? I mean my bow tank was totally empty, I filled it with 39 2L bottles or 168LBs of floatation.
Assume I did nothing else to the boat, and left both seat tanks as is, how can this boat float while the cockpit and bilge is full of water? I know it will, I was up to the gunwales in water with 4 people onboard and it was still floating. The only thing i can think of is that the top half of the inner hull traps enough air to keep the boat afloat.
My new concern is that the inspection ports aren't airtight and that if I'm hulled they will leak the air they trap and I'd be worse off than if i'd done nothing.
