No prob!
Never really thought about it before, but isn't it interesting that there's *just* enough room/travel between the trunk and mast step for the uphaul?
Things that make you go hmmmm ...
GreenLake wrote:Capt Dave was last seen on these pages in 2009. His profile may have an e-mail, if so, that might be a way to reach him.
TIM WEBB wrote:Just took a look, and I'm getting right at about 14-1/4". Measured it on the trailer: since I know where the swedge is when the board is down (just forward of the donut where the cable exits the trunk), I just measured from there to where the swedge is with the board all the way up (on the trailer).
jdoorly wrote:This will probably require a new longer wire rope for the centerboard-up, which means freeing the cable ends from there stupid hiding place and creating a better up/down system (i.e. one where the wire doesn't get caught on the side of the centerboard, a problem for which there doesn't exist enough salty language.)
jdoorly wrote:Are you planning a hand crank for your spool? Normally a system like you describe has an idler pulley somewhere to keep it tight enough. I would think you will have to sink a block down into the trunk so the up cable doesn't eat into the top of the trunk (this is happening in mine).
BTW my uphaul connection to the CB is the same a CaptDave's, but my downhaul is only 1.5" away whereas his is completely on the opposite side of the CB (and when the CB is up it looks to be exposed (in the slot) to the bottom (rocks and sand).
TIM WEBB wrote:Isn't that the downhaul you're talking about moving? Doesn't your downhaul exit on the top of the CB trunk? If so, how will you route the DH line from the new lower and offset fairlead to the top of the trunk, so it's still pulling straight forward? Just wonderin' ... ?
