I'm glad we're having this conversation - I just discovered something new about my boat. The base of my mast stub isn't on top of the compression post at all, as I'd been thinking for 10 years. It's completely aft of it, just about where yours is. In this photo, you can just see the two long screws that secure the mast foot to the cuddy floor.
- DSII compression post and mast base screws.jpg (111.69 KiB) Viewed 15255 times
What else is interesting is that the mast stub, when attached, is angled forward at the top. When I disconnected it from the cuddy floor and placed it in a vertical position, it moved to a point that's probably directly on top of the compression post. So, in other words, if my mast stub had been attached to the cuddy floor where it should be, I'd probably be a lot closer to 11 feet than 10' 10".
If you place your mast base on top of the compression post, how close is it to vertical?
