MAST CONNECTION AND HINGE
Postby mndaysailer » Wed May 03, 2006 10:51 pm
NEW TO SAILING AND JUST AQUIRED A DSII. I TRIED TO SET UP THE MAST, BUT THE PLATE ON THE FLOOR OF THE CUDDY WAS LOOSE AND BOLTS CAME OUT, WHAT DOES THIS PLATE ATTACH TO UNDERNEATH. ALSO I HAVE ONE HINGE ON THE MAST JUST ABOVE THE CUDDY ROOF, BUT IS THERE ANOTHER HINGE KIT SO I CAN LEAVE MAST ATTACHED AND TRAILER AND TOW THE BOAT. THANKS
mndaysailer
mast transport
Postby Roger » Thu May 04, 2006 8:48 am
If you leave your mast attached with one bolt at the tabernacle (hinge), the top part of the mast will stick out way behind the boat, causing a danger to others and more significantly, place undue stress on the mast. What most people do, is make a stirrup on an extension of the winch post of the trailer and cradle the base of the mast there. You can use a scissor crutch for the back, or construct something that fits into the rudder gudgeons to support the back (top) part of the mast during transportation. Check pages 1 and 2 in my website album to see how this is done.
http://groups.msn.com/RogerConrad/shoeb ... lbumlist=2
Don't forget to tie the mast down during transportation. Also if you are travelling a long way, you may want to secure the middle of the mast to the tabernacle or support it with some cushions or old PFD's.
As for the mast plate, there is a backing plate under the cuddy floor and integral to it, supported by a short post that is fiberglassed in both top and bottom. The plate just screws into the cuddy floor and into the backing plate. You can see it on page 2 (4th picture) in the above mentioned website.
I have a book on maintenance and repair of the DS if you are interested. See the top note in the DS II section of the general forum.
