topping lift ???
topping lift ???
Postby smithel » Tue May 12, 2009 5:23 pm
what is a topping lift used for ?
smithel
Postby GreenLake » Tue May 12, 2009 6:04 pm
to hold up the boom when the sail is down.
topping lift
Postby kokko » Wed May 13, 2009 7:55 am
It is a line run from the top of the mast to the end of the boom to support the boom when the sail is down. Most are somewhat adjustable. Mine runs from an eyestrap at the top of the boom to a cheek block at the end of the boom, to a cleat on the boom.
Postby seandwyer » Wed May 13, 2009 3:37 pm
Is this normal? I don't have one. When my sail is down, I need to keep the boom in a crutch or it just flops down. Am I missing hardware?
Sean
DS1 - 3203
seandwyer
Postby kokko » Wed May 13, 2009 3:54 pm
Mine runs from an eyestrap at the top of the MAST to a cheek block at the end of the boom, to a cleat on the boom.
With the sail up, the sail itself supports the boom. With the sail down, you need a boom crutch or a topping lift. THe boom Crutch did not work for me.
I did not have one either, so I added it. Easy with pop rivets or self tapping screws.
