last August my mast fell over while the boat was moored. the PO had screwed the mast to the step casting so that got broken and the tabernachle plate was bent. I got new parts but I am in need of the tappered adjuster nut that threads onto the end of the sidestay inside the turnbuckle. I cannot locate this nut locally, local sail shop says my system is old school. West Marine does not have the nut. I am not sure if my stays are 1/8" or 5/32"
the boat was given to me as a tip last summer while i was bartending, it is in excellent shape and I really want it back in the water.
i think upon stepping the mast, I am not going to drill screws into the new casting, is this a good idea? just slip it into the mast end and step the mast, connect stays and go sail? or should I attach it with srews or rivets?
thanks
my turnbuckle setup looks kind of like this lifeline adjuster:
picture labeled adjuster, second row on right side of page. the long one
http://www.apsltd.com/c-1343-lifelinetu ... tings.aspx
I can post actual pics if needed. just looking for the 1 tappered nut. mine is in the lake somewhere. anyone have any old spare parts or this nut?
thanks again for the helps
Forrest up in northern Michigan
