distance between bench backs
Postby BreezingUp » Sat Jun 30, 2018 1:03 pm
Does anyone happen know the distance between the bench backs inside a Daysailer II cockpit? Alternatively, the width of the gunwales? I need to know and am not near my boat. Thanks.
1982 DS II #12047
BreezingUp
Re: distance between bench backs
Postby Alan » Sat Jun 30, 2018 2:24 pm
The beam is 6 feet three inches, if that helps (winging it from memory).
Postby BreezingUp » Sat Jun 30, 2018 3:58 pm
Hi,
Yes, I know that part - but I need the distance inside the cockpit, from the back of the bench on one side to the back of the bench on the other.
Or, if I knew the width of the gunwales, I could subtract twice that from 6' 3".
Thanks.
Paul
1982 DS II #12047
BreezingUp
Postby Alan » Sat Jun 30, 2018 6:48 pm
OK, I'll be able to measure it Tuesday, if no one has chimed in by then.
Postby GreenLake » Sat Jun 30, 2018 8:21 pm
Whatever you do, don't assume right angles and straight lines on a boat.
Where in the cockpit do you need that measurement - aft, center of forward? Bet the numbers have a good chance of being different. . .
(No access to a DSII, otherwise I'd send you number).
Postby BreezingUp » Sun Jul 01, 2018 10:56 am
Aft
1982 DS II #12047
BreezingUp
Postby thistle3930 » Mon Jul 02, 2018 2:49 pm
I hope this isn't too late for your needs. My DSII project boat is still in my carport as I have been out of town and it way too hot here to work outside anyway. At the aft most point I could measure the highest point on the "seat backs" are 49-3/8" apart. At the point where the main sheet block & cleat are attached to the CB trunk they are 55-7/8" apart. As close to the cabin as I could measure they are 52" apart. Within the limits of me holding a tape measure by myself, of course.
John Garner
DS II 7956
thistle3930
Postby BreezingUp » Mon Jul 02, 2018 9:36 pm
thistle3920,
No, not too late at all - that's very helpful. I just want to put a piece of plywood across the benches to raise my homemade boom crutch (and the boat cover that goes over that).
I asked about the measurement because my boat is moored at a lake an hour away. Thanks for you help!
1982 DS II #12047
BreezingUp
Postby Alan » Tue Jul 03, 2018 5:39 pm
Oops, I misunderstood the question and measured between the inboard edges of the seats, but since I made the measurements, I might as well immortalize them here:
Aft: 24-1/18 inches
Right behind the mainsheet block on the centerboard trunk: 31 inches
Forward, at the two rounded corners just behind the cuddy bulkhead: 28-1/16 inches.
Postby BreezingUp » Thu Jul 05, 2018 12:00 pm
No, I think your first answer was what I wanted - the distance between the backs of the benches (what you lean back against). That must be 49 3/8", not 24 1/8".
Thanks again.
1982 DS II #12047
BreezingUp
