daysailer 3 mast dimensions
Postby sailboatgarden » Sun Jun 25, 2006 11:04 am
i just bought a daysailer 3 and it has an aproximately 3" damaged section on the bottom of the mast that hs been cut off and discarded. I am looking for the exact dimensions of the mast so I can repair it.
Are the masts of all daysailers (1,2,3) the same?
Where can I get a manual for the daysailer 3 that may have the rigging dimensions?
I need this info quickly as I have to move the boat this week.
Thanks for your help
sailboatgarden
hit the link below
Postby Roger » Mon Jun 26, 2006 1:20 am
hit the link below or check under Daysailer Association on this page, drop down menu... handbook, then specs and measures... section 7 discusses spars and their lengths.
http://forum.daysailer.org/pdf/dsbylaw3.pdf
Return to Day Sailer III Only
