The mast does not sit squarely on the heel, you may be able to tell some gaps. The nuts that hold the plate in place need to be tightend a little (the plate is bent a little, somewhat from the bolts being overtightend I think - not by me). Just wondering its safe to sail with it like this or if I need to redo the repair. If so how I should go about it. It looks like original bolts/rivets were removed and new bolts screws inserted in new holes.
Photo links are:
