Painting boat name
Painting boat name
Postby jefflw » Wed Feb 25, 2009 1:39 pm
I want to paint the name of my boat on the transom of my DSIII. Any suggestions on type of paint.
Tx
"Swallow" DSIII
jefflw
Postby GreenLake » Wed Feb 25, 2009 9:51 pm
Use a contrasting color to your hull :D
(couldn't resist that one...).
You don't write whether your hull's been painted or not. If so, that would affect the choice.
If not, you might look at alternatives to paint, including getting a name printed on foil, which you could apply as one piece. That gives more freedom for design than what you can realize with paint. According to what I read, the result should be quite durable.
Vinyl Lettering
Postby MarcCram » Wed Feb 25, 2009 11:02 pm
Along with foil have you thought of vinyl?
My parent's had their boat name cut in vinyl 20 years ago and after moving from New Jersey to Rhode Island my father brought the True Type font that was used to the new lettering guy and he cut a new town name for him. Removing the old lettering, which was maroon and hadn't faded either, wasn't difficult to do.
As with foil, you don't need to worry about your spacing, it's on one sheet and is faster to apply and doesn't need to dry.
marc
MarcCram
Postby algonquin » Thu Feb 26, 2009 8:48 pm
Here's a link I used a while back for some lettering on my 69 Dodge Coronet drag car. It's really boat lettering :wink: Brad
http://www.signspecialist.com/lettering ... ering.html
Check your local Yellow Pages. You may find someone nearby that does the same thing.
Postby algonquin » Thu Feb 26, 2009 8:59 pm
Hmmm ! Back to your original question. :o
As odd as it may sound I have used Rustoleum paint products to letter on different surfaces. I have also used it to paint one of my boats. It comes in a variety of colors plus it is very durable and color fast, and it is far cheaper than speciality marine paint. You may want to thin it some. Brad
Boat names
Postby kokko » Fri Feb 27, 2009 10:42 am
I have used vinyl leterring. West Marine has an online site for boa names - you can choose the color, font and size and see what it looks like.
I found West to be pretty expensive and found a local sign shop that did it for half the cost.
Return to Day Sailer III Only
