Draft letters
General announcements and information specific to the DaySailer forums.
Draft letters
Postby Cliff » Fri Oct 31, 2025 12:17 pm
I saved a draft letter but am unable to find it. Help!!
Cliff
Cliff
Re: Draft letters
Postby GreenLake » Fri Oct 31, 2025 9:35 pm
Assuming this was a saved draft of a reply: Go to the topic to which you replied. Reply again and there will be a new button below to load a draft. That brings up a list from which you can select your saved draft.
Saving a draft of a first post in a new topic is similar, but you have to start a new topic again in the same place to be offered to load your draft.
If by "letter" you mean a direct message, you'd have to experiment a bit. They share some similarities with posts and topics so it might work in a similar way.
Return to Forum Info and How To Use the Forum
