I am interested in finding out if anyone has a DS II in or around Portsmouth, NH.
I would really like to look at how the boat is rigged for the centerboard raising and lowering via the cable and rope routing. Also how the jib sheets are secured in the cockpit along with the centerboard cleating on the side of the centerboard trunk. Should there be some rubber gasket surrounding the up C/B cable as it exits the forward edge of the C/B trunk? Does the smaller drain hole on the outside bottom of the transom have a plug that seals this hole or should it reamin open?
Thanks for any information
ABIDON2 (ABIDON2-at-AOL.COM)
