MY Beginers Pond
MY Beginers Pond
Postby Fly4rfun » Sat Nov 21, 2020 8:26 pm
]Here is a diagram and google map image of the 22 acre lake 9Bathtub) i try to sail on
1-Fullscreen capture 11212020 154429.jpg (93.3 KiB) Viewed 31249 times
i meant to put this in Miss.
"Sail Aweigh" 1966 DS1 #2675
Fly4rfun
Re: MY Beginers Pond
Postby GreenLake » Mon Nov 22, 2021 11:53 am
"Locations" is the right place for this kind of info Tell us more about the place.
Postby Fly4rfun » Sun Nov 28, 2021 1:27 am
GL, Its a small 22 acre fishing "lake" called Dog Run Lake off hiway 50 near Salem ,WV. has a park no gas motors allowed. they stock it with rainbow trout a couple of times a year.has a depth max of 38 ft . the wind seems to run out in the summer around 4 pm. the problem with it , as you would expect you can barely get your sails set when it is time to tack. Its close to my place and good for testing out the boat and rigging configurations. next closest lake is Tygart lake, which is 1750 acres and 10 miles long. have not sailed there yet, those plans were interrupted by a little surgery I had. but next year, its only 39 miles from home.
Fly4rfun
Postby GreenLake » Sun Nov 28, 2021 3:07 am
Garry. it looks like this would be the kind of lake where you'd need to set your sails before pushing off. :)
Otherwise, having a narrow channel can be a great way to practice tacking or gybing.
Postby Fly4rfun » Mon Nov 29, 2021 10:14 pm
GL, yes sails set before. plenty of practice with turns
Fly4rfun
Return to Fleets/Locations
