DS 1858 wrote:I assume carbon is not class legal in the DS, something to consider.
I got a note back from Bob Damon (the class measurer) regarding the use of carbon fiber to reinforce or stiffen the hull. The class rules are pretty liberal regarding stiffening the inside of the hull. Although he was not aware of anyone using carbon fiber he said that steel rebar has been used in the past! So, it is class legal to use carbon fiber for reinforcement on the inside of the hull.Phill wrote:I know for sure, that any exotic fibers, carbon, kevlar etc, is forbidden in the building of the CB and Rudder.
For stiffening, shoot a question to the Measurer, Bob Damon is still 'IT' i thinik. I have been see'n carbon fiber tiller extensions and spin poles.
For stiffening, I would question the value of the extra stiffness that an exotic might add. Given that the boat has some flexing as a whole, I wonder if maximizing stiffness in one area, might force another area to carry more of the flex and.....fail ???
just about .02 cents worth.
K.C. Walker wrote:The class rules are pretty liberal regarding stiffening the inside of the hull.....steel rebar has been used in the past!
Now this is interesting. Reaching up under at the edge of the cuddy on my boat, I'm pretty sure that I've got the rebar. Fortunately, I don't see any rust stains yet. I wonder if I should sand that area lightly and give it a coat of epoxy as a preventative sealant. It makes me look at that gelcoat crazing a little more critically. And, my boat is 7002.Phill wrote:GreenLake,
The class didnt have to accomodate the " Steel Rebar Faction".
O'Day built many DS 1's with steel rebar glassed into the upper aft inside edge of the cuddy top. If you have a 1000 to about 3000 boat (maybe more) run your fingers on the inside of that edge. You should feel the rounded glassed over approximately 3/8" rebar reinforcment that supports your weight when you stand on the rear edge of the cuddy.
Humm... probably not a good place to put a compass!GreenLake wrote:One never stops learning. In a way, I'm glad I made my flippant remark - or I would have never leared why magnets stick to my cuddy rim :-0
(Like K.C., I didn't have any telltale rust to alert me).
