Hello all!
I just bought my first sailboat, a red 1972 DS II. It's in pretty good shape for a 37-year-old boat, but there are a few questions I have, and I figured this was the place to go for answers.
First, the inside of the cabin is pretty nasty. Does anyone have any tips on cleaning that space? I would assume a rag or a sponge and some soap would do the job, but I don't know if there are certain soaps that might not get along with the material of the deck. Would pressure washing be a terribly bad idea if it turns out that the scrubbing isn't doing it?
Second, I noticed that one of the spreaders has broken at the hole for the pin, and the previous owner had simply drilled another hole in front of it. Is this going to pose a problem that one of the spreaders is an inch-and-a-half shorter than the other? Is there any reason I should not consider making spreaders out of some stout hardwood?
Third, I'm replacing all the running rigging. None of the rigging looked to be in dangerously bad shape, but it was clear to me that much of it was either original or close to it, and it was dirty and uncomfortable in the hands. Based on what I took off the boat, it looks like everything is 1/4" except for the mainsheet/traveler (which was all one huge piece before, but I believe I'm going to change that) and jibsheet, which are 3/8". Can I just buy stout climbing/utility type rope by the foot at Home Depot, or does it have to be specifically sailing rigging?
