On the topic of crazy things previous owners have done, the mast on my DSI was cut at a slight angle about a foot or so above the cuddy, and the previous owner fabricated an aluminum "sleeve" into which the top portion of the mast slides down to meet the bottom portion. The sleeve has drilled holes which align with drilled holes in the mast, allowing the insertion of bolts above and below the cut secured with wing nuts. You can imagine the difficulty stepping and lowering the mast with this arrangement. For example, I cannot do either of these tasks with the side stays attached. My partner and I must lift the mast vertically (and precariously) while trying to slide it into the sleeve.
Anyway, I want to cut the mast at proper 90 degree angle and install the hinged tabernacle available from D and R Marine. In doing so, I will likely lose about an inch (perhaps a bit more) of the mast height because I will be removing the slight angle on which the mast was previously cut. Sounds confusing, but take my word.
The question is, will this loss of an inch or so cause a problem? I'm thinking that the only real problem would be the length of the side stays and forestay. Both are on turnbuckles and I may be able to adjust them to accomodate for the lost inch (don't know for sure ... must wait till I get the boat out of the barn in the spring). Should I install a little "lift" at the mast step on the bottom beneath the cuddy to compensate for the lost inch? If so, any suggestions for how to do this? I'm thinking that a small wooden block screwed and epoxied to the stringer beneath the current mast step should do it. Lastly, for you guys with metalurgical engineering skills, will the integrity of the mast be compromised by having those holes drilled through it if I no longer need the through bolts? My guess is "no" but would appreciate your advice on this.
Kevin Kearns
