by John McGrath » Wed Mar 17, 2010 12:09 pm
I installed a tabernacle a couple of years ago, and it's made all the difference. Though purists will say the (formerly monolithic) mast is ruined because its bending properties are now altered, I don't agree. There never was much bending to be had right down there where the mast passes through the partners anyway. Plus, if you installed it on an older mast, it was unlikely to be that bendy to begin with. At first I was reluctant simply because tabernacles are ugly, but I really, really couldn't step the original mast by myself without feeling I was risking all the parked cars around me. Now, with the tabernacle I can go singlehanding very easily. I just use a single pin--the aft one--while sailing. This may be debatable, but works fine. Seems like asking too much of the tabernacle to ask it to transmit bending loads instead of serving as just a pin joint. I have an older DS1 with the bronze tensioning ring + post type of step. I think later DS's may not have this. I drilled a hole through the mast and mast step post with the tensioning ring screwed all the way down. Whenever you raise or lower the mast, you've got to have a pin passing through the step (or some other arrangement) to keep the bottom mast section secured in place. Otherwise when you got to raise it, it will lift up and off of the step. Makes a hash of things. After the mast is up, remove the lower pin, then tension the rig with the tensioning ring on the step. The shrouds and forestay tension simultaneously. Don't forget to reverse the process when unstepping. If you don't, that lower section comes flying up as you lower the mast. It's a CG thing. Surprise! The nice thing is that the side-stays (shrouds?) can stay permanently attached. No need to disconnect them at all while trailering.
Love my tabernacle.
