dbk0630 wrote: ... and like that with the added resistance of the ratchet, it's easier to uncleat and I can even hand-hold the main, without white-knuckling, when necessary. So, while I would likely to change to an upward facing cleat/swivel setup at some point, the downward facing cleat seems less bothersome with the mid-boom ratchet installed.
K.C. Walker wrote: However, I'm contemplating switching back. As a cruiser with a motor on the transom I get some very scary fouling of the lines just at the wrong times. I almost dumped the boat the other day when the wind was up and I fouled the motor on a tack (and I thought I was being careful to pull in all the slack line).
