Over the summer I had my DS1 on a mooring, while I had to work, I had to have my wife out to bail it everyday. The boat would fill with 2-3" of water every day, until she was relieved on the weekends.
I suspect the leak is coming from the centerboard area. The area in question is not on the centerboard handle side but further up on the otherside underneath the cuddy, where there is a gasket fitting 1.5" dia with rubber gasket & a brass fitting with a T-stop in it.
Is anybody familiar with this kind of fitting?
Also, I had the hull interior re-gel coated earlier on in the season, the chap that did the job, mentioned puddling of water coming up from the centerboard area, even after being in the shop for some time. Any thoughts on that?
Please & Thank-you
