I have been using a 1/8" line rove through a small hole in the aft edge of the rudder to pull it up and secure it up for trailering. But, on several occations the rudder has raised thirty or forty degrees while underway and if the troller motor is running the propeller can strike the rudder. A week ago this occured with the sails down in a skinny channel and the shear pin in the prop sheared. I had to anchor for an hour while I tried to figure out what happened and how to fix it. I was able to temporarily replace the shear pin with some of the broken pieces of shear pin.
I have a standard rudder and have found deploying the rudder has been a PITA! as I have to bend over transom and push hard on the top edge of the rudder to make it go down (not that I ever noticed a difference in performance whether it was up or down). So I was in the mood to do something about the rudder problems.
I thought about using auto-release clam-cleats; a good idea but much more expensive then my final design. I decided I wanted a lever that would mimic the rudder and indicate whether the rudder was up or down or how far down. I also wanted to be able to lock it down if I became frustrated with water pushing it up, and also have the option of using shock cord to hold it down. And, some way of easily locking the rudder up for trailering. So...
[thumb=1054]
There is a small screw just above the axle/bolt in the lever that can catch the lever and hold the rudder up. When the rudder is deployed the triangular section points down and if you force the lever further the geometry of the triangle will continue to move clockwise and lock the rudder down. It is working so well I haven't added the shock cord yet.
Oh, I can still raise the tiller and grab a cold one from the cooler I keep under it. I got the 1/8"x1"x36" aluminum bar at True Value for $8.00 and the 5 1/4-20 ss bolts and 2 screws out of my stash. The dimensions are important but I forgot 'em, ask me and I'll measure them.
