Just was given a '68 Day Sailor in great shape! Except for a broken step-hinge.Option #1.... Would it be advisable to cut the damaged portion of the mast (approx. 1 inch) and re-attach the step, which is in good shape, with a stainless steel bolt? The step was ripped off the bottom of the mast with the rivets, which in turn damaged the rivet holes on the bottom of mast. Option #2... Any merit to having the step welded on the bottom of mast? Which I have access to a friend who can properly weld aluminium. Would appreciate any input...Thanks
Joe Phillips (biggs-at-usa.net)
