I've just launched into that project. Last done about 8 years ago, the varnish had essentially disintegrated anywhere these were stepped on. The thwarts, which were done 6 years ago (and also get stepped on a bit) instead look like new.
The little "feet" (cross-ties) had partially separated, and some of the nails/screws were beginning to stick up. This is true mainly for the aft set of them. The forward set, where shaded by the cuddy, has retained much of the varnish, and the feet are more firmly attached.
So far, I've taken apart the floor boards and sanded them to bare wood (on the top) and almost to bare wood on the bottom; the boards are extensively cracked on the bottom, and they are cupped, making it difficult to get existing varnish off, I'm hoping what I have is good enough to support what I want to put on.
I used a hot air gun and a scraper, that worked really well on the top to get most of the remaining varnish (PU) off. Then sanded with 60 and 80 grit. Alternatively, sanding with 40 grit also cuts through the varnish.
I discovered that the individual slats do not all sand to the same color wood and that they seem to have weathered differently. To even out the color, I'm using a stain on them. That seems to have been done before, because in places where there was original varnish still left, the bottom most layer had a distinctive hue. I chose "maple" as the stain color that seemed most likely to result in a more uniform color without being too dark.
The plan is to let that sit and cure well, then coat with SystemThree ClearCoat (3-4 coats) and then their Waterbased LPU (4 coats). The LPU should have enough UV protection and, if the thwarts are an indication, this should give me a reasonably long life-time.
I'm planning to epoxy coat the little feet separately and even put a layer of glass on the bottom, to prevent the coating from rubbing through. Not sure I want to glue them on. While permanent, it's too permanent, and would interfere with disassembly for recoating. Probably screw them back on, after reinforcing the holes with epoxy. For the extra fasteners that were added over time as the original locations failed to hold, may just glue in their heads, for optics.
