Sloghtly confused about my new CB cable kit. My DSII CB uphaul steel cable is totally shot. I picked up new cables and a new bolt from D&R to replace them, hopefully this weekend.
http://www.drmarine.com/proddetail.asp?prod=DS106b
According the the DSII book, the uphaul line is a 1/4 laid line, and on my boat and all the pictures I have seen the uphaul is not a SS cable.
So I am not sure if the two cables in the kit I received from Rudy means one is a spare, or if I should use both cables, one for the uphaul and one for the downhaul?
If I should just use one, is there any particular "type" of 1/4 line I should buy to replace the downhaul?
If it makes any difference, my DSII CB Trunk appears to be standard, with one hole for the uphaul at the front bottom of the CB trunk in the cuddy, and the downhaul on top of the front part of the CB trunk, also in the cuddy.
