Hi Folks:
Dunno about your neck of the woods, but it's been GORGEOUS sailing weather here in North Carolina, best spring ever, and I'm stuck - local lakes are closed! So, after dithering around all winter, I'm finally cracking down on a few long-awaited "improvement" quarantine-time projects. Something like home "remuddling", just worse. For what its' worth, I'll post some pics here, either as inspiration or warning to others, you decide.
My boat is (still unnamed) hull #37 from 1958, if you search on this forum you'll see how I took her from a wreck to sailable. Now, I'm wrecking her again.... and of course, I'm basically taking on 5 projects at once and pushing each one along a bit when I feel like it/have time. So please don't mind the mess!
Project #1 is to finally put in a centerboard tree/console (see the post "lumpy bottom) for a full explanation. My dream is this (from a newer DS1, not mine!):
Why? Stiffen the boat, and add a place to put control lines, cleats, etc, get them off my cabin-top. So, first step was to measure. From the bilge to top of centerboard is 1 foot on my boat (it's more on newer boats). Then it's 2 feet from the top of CB to the bottom of the cuddy. Splay out 10 inches and there you have your basic triangle. I drew that out on a big piece of cardboard, used a batten to draw a smooth curve, cut it out, transferred it to a sheet of leftover plywood and made a template:
Old #37 is one of the "Wooden Bench" DS1s.. the old seats are solid mahogany, pretty rotted at the edges but just fine in the middle (those are the seats in the pic up above, being used as a table). I've made new seats but saved the old ones for just this occasion:
Now, this is just a test fit (note the clamp) but worked out how I wanted. I cut the "arms" of the tree out with a 3hp router (straight bit), using the plywood template tp guide me. I cut two layers for each side and glued overnight with my favorite, Gorilla Glue. I've been using it for years, works great for wood to wood, if you have a good fit and are careful not to squeeze too much glue out of your joint. Anyway, I'm happy and now off to shape the arms.... prepare for more woodworking blasphemy!
