So I'm about to do my first ever fiberglass repair on the hole I mentioned in my painting thread (which has gone way off topic.) I already cut the hole out how I want it and made it a gradual slope etc. etc. Greenlake tutored me on how to put a backing on the inside (it's below waterline on the hull.) My question is how the heck do I do the exact steps to repair. Here's what I've gathered from watching YouTube videos (if there's an instructive how-to buried amongst the posts here, please let me know a keyword as "fiberglass repair" & "epoxy" etc. are too general of search terms.)
THE STEPS AS I UNDERSTAND THEM:
1. Clean surface with acetone
2. Prepare my epoxy. 5 parts epoxy to 1 part hardener.
3. "Wet out" the repair surface with above epoxy, leaving a thin layer where repair will go.
4. Cut out patches in decreasing size, with the largest covering the whole 1:12 repair area, and the smallest being the size of the actual hole.
4.a. QUESTION: How do I know how many of these patches to make? And is all fiberglass cloth the same? I've heard about bi-axial 1708 cloth being good for repairs? Are there different thicknesses of cloth? Do I need to measure my hull with calipers and then somehow "add up" the thickness of the multiple layers of cloth so that it equals hull thickness? How do I know the thickness of the cloth?
5. Wet out the fiberglass cloth with the mixed epoxy, either ON BENCH OR ON BOAT ITSELF?
5.a. QUESTION: Do I combine all the patches together, wetting them out individually and stacking them on each other on the bench (on something called peel ply?) and then apply them all at once to the boat, or can I wet each one out onto the boat one at a time?
6. Squeegee out bubbles in the patch(es) of fiberglass.
7. Wait for fiberglass to become tacky
8. Mix some fairing compound into a small batch of mixed epoxy.
9. "Fair" the repair with a squeegee? of some sort to make the boat hull seem more flat
10. Wait for that to dry?
11. Apply some unthickened epoxy as the final layer.
12. Use a piece of sandpaper on a long piece of flexible wood to sand the repair and further fair it to the contour of my hull.
13. Wash all that with soap and water? Then sand with 100 grit and paint.
Did I get that right?
What I need to buy first:
Epoxy and hardener
Fairing compound
Acetone
Some kind of squeegee/scraper
Cups for mixing and measuring epoxy
Fiberglass cloth (how thick? what kind?)
