Plugs from D&R Marine
Postby Anstigmat » Sat Jan 16, 2021 7:04 pm
http://www.drmarine.com/proddetail.asp?prod=DR020
http://www.drmarine.com/proddetail.asp?prod=DR236A
I bought these for my DS1 and they do not even remotely seem to fit. Are these for the DS2 or 3?
Anstigmat
Re: Plugs from D&R Marine
Postby GreenLake » Sat Jan 16, 2021 7:15 pm
The dimension of the hull drain on older DS1's seems to be non-standard by now. Everybody carries piugs that are too big. You might like to take some calipers and measure what you actually have for an ID.
A DS1 (except a recent one) should not have an inner hull. Now, if yours is a recent DS1 with the inner hull, perhaps contact Cape Cod Shipbuilding.
Postby tomodda » Sat Jan 16, 2021 7:20 pm
Where is your drain hole?
Postby Anstigmat » Sat Jan 16, 2021 8:21 pm
There is one drain at the transom, and another just behind the centerboard.
I think you're right, I'll have to measure them to get the right part. I should have the originals, they just look a bit tired.
Anstigmat
Postby jalmeida51 » Sun Jan 17, 2021 12:04 am
On my Daysailer1 there is only 1 drain plug located at the transom. Built in 1981 by Rebel with the inner hull. (liner ) I went to West Marine and found one made by Ronstan.
jalmeida51
Postby GreenLake » Sun Jan 17, 2021 2:25 am
Then one behind the CB takes some standard pipe thread (I found it useless and glassed it over, but my trailer is parked on a slight slope so the rear drain works well).
