Wood for floor and coaming
Postby Mike M. » Tue Oct 11, 2005 11:15 pm
My '68 DS I came with no wood (removed by a previous owner) and I'd at least like to have a floor. A new friend, a DS owner nearby, will graciously allow me to pattern his but I'm having a difficult time finding mahogany. I'm capable of doing the woodwork. Anyone have a source for raw materials?
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby michaelyogi » Wed Oct 12, 2005 2:39 pm
Try www.bearcreeklumber.com
They might be a little more expensive but the wood quality and the service is good. Be sure to let them know this is for a boat.
Another wood to consider is Alaskan Yellow Cedar. Might not be the right color but the rot resistant properties are really good and it's durable also.
michaelyogi
Postby Peter McMinn » Thu Oct 13, 2005 1:42 pm
Go with mahogany. It's strong, easy to shape, and holds varnish better than teak or cedar as it doesn't bleed nearly as much oil.
I replaced all the old wood on my 1960 DS1 with Philipine mahogany I found at Crosscut Hardwoods http://www.emersonhardwood.com/cchw/categories.asp
Probably could have gotten it at other places but Crosscut had the dimensions I needed for the seats (1x12). It was all rough cut and under a hundred bucks, as I recall.
Look for "certified" lumber harvested from a plantation rather than torn out of a rainforest cleared for pastureland (my $.02).
Another possibility I'd considered was cutting/shaping the pieces I needed out of cabinet-grade plywood, then soaking it all in epoxy. This would have been expensive due to the amount of epoxy, but if you have a cheap source, it could be economical.
Peter McMinn
una mas
Postby Peter McMinn » Thu Oct 13, 2005 3:15 pm
Here's another thought. If you can't find raw mahogany lumber near you, try looking for old futon frames, maybe on craigslist. These are often made of mahogany that could provide just the dimesions you're after.
Peter McMinn
Postby Mike M. » Thu Oct 13, 2005 11:24 pm
Thanks for all the replies. I'm on the trail of some mahogany 2 x 4's and there're two different places that will rip and plane it for me locally. I'm waiting on quotes now, I'll let you know what I find out.
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby Mike M. » Sat Oct 15, 2005 10:52 pm
I can get 1/2" x 4" x 72" mahogany for $10 a board buying 20 each. Does that sound like a good deal or too much?
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby michaelyogi » Sun Oct 16, 2005 2:36 pm
$10.00 a bd ft!!! :shock: OUCH!!! Granted alot of milling went into getting 1/2" thickness but still....
michaelyogi
Postby michaelyogi » Sun Oct 16, 2005 2:43 pm
I'll check around and see what I can find for ya'. I think it sounds high. I might be wrong but I think the last time I bought Mahogany (Honduran I think) it was $6.00+ bdft. I'll try to be quick about it as I'm leaving soon for a sailing trip... Keep your fingers crossed.
michaelyogi
Postby Mike M. » Sun Oct 16, 2005 8:49 pm
That's $10 per board 1/2 x 4" x 72" not per board foot. The price I was quoted for 2 x 4 x 6-0 was $5.81 per board foot.
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby Mike M. » Sun Oct 16, 2005 11:42 pm
Oops! You're right, 1/2 x 4 x 72 is a board foot!
Mike Miller
DS I #3780
"Patty K"
Central Oklahoma
Mike M.
Postby michaelyogi » Sun Oct 16, 2005 11:47 pm
Now you see what I'm talking about! The 2x4x72 is actually 4bf and a much better price. I just happen to have a full blown woodshop so I would opt out for the 2x4's. If you don't have access to a full on shop the 1/2" material might be the way to go.
michaelyogi
