Roger wrote:At our marina, we use cement filled tires. Place a green garbage bag inside a rubber tire to act as a bottom "release agent". (It can be torn away after the cement has set.) This acts to create a bottom across the lower rim of the tire. As you pour cement in, of course, it will press down and slightly out around the lower rim to form to whatever base you have the tire on. (Driveway, parking lot, grass, etc) As you are filling it, place a V shaped piece of 1/2" rebar upside down (/\) into the centre of your cement. Continue to fill the tire, shoveing cement under the rim. Let it set. Remove the plastic garbage bag. Attach a chain, and roll it onto the boat you plan to use to deploy the mooring from. Need more weight? Use more tires. Individually, they can still be moved (with difficulty), but chained together, they are impossible. It will be well past your children's lifetime when the rebar rusts through. The beauty of this system is that they are easly rolled to where you want them, after they have been manufactured.
