Bent Board Handle
Bent Board Handle
Postby Triche » Wed Jan 03, 2007 11:12 pm
I just bought hull number 9232, I think. 1964? Anyway the board handle is very much bent. I think is it bent to the extent that the board won't go down all the way..... So I was wondering, it is bronze I believe, can it be heated with a torch and straightened out, or what should I do?
Thanks in advance. [/quote]
David Triche
9163356838
Sacramento, CA
Triche
Postby Peter McMinn » Thu Jan 04, 2007 7:23 pm
I have the same issue, and in a month or so, I'll be taking it on as I also fair the board (reason for the bent handle). I had the same thing in mind, but would be interested in whether heating the metal would weaken it.
Expert opinon needed.
Peter McMinn
Postby swiftsail » Fri Jan 05, 2007 2:00 pm
Personally I had a new one built out of Stainless and as a secondary purpose I use it to keep my crew in line. (It's a bit beefier than the original)
DS 307 "Security Risk"
DS 14024 "Flight Risk"
Live Slow, Sail Fast
swiftsail
CBoard Handle,
Postby Triche » Fri Jan 05, 2007 2:23 pm
Swifty,
Did you do it yourself and how much did it cost. I guess I could cut it off and attach a pipe. That would look very Rube Goldberg, but seriously, can they be straightened with heat. I am not the familiar with the propertied of bronze other than it is soft. Actually, I don't need the handle to keep order, at least I don't think. Although, self flagellation might make me sail better, but since I don't have a crew that doesn't seem necessary.
David Triche
David Triche
9163356838
Sacramento, CA
Triche
Postby Peter McMinn » Fri Jan 05, 2007 2:55 pm
I have seen stainless pipe fitted over the stub of a broken handle. With some bicycle handle grip on the end, this seems to serve the owner well.
I'll probably resort to this if the handle breaks as I heat/bend it back to shape.
Peter McMinn
Postby swiftsail » Tue Jan 09, 2007 1:43 pm
I had it built about 10 years ago buy a local machine shop for about $100.
I also have seen various pieces of pipe used to correct this flaw in the Day Sailer design but I wanted a solution that I was never going to have to worry about again. Specially at that last minute "Oh S@#$, put the board down" as you are about to round the leeward mark.
swiftsail
Bent Board Handle
Postby Wyatt » Fri Jan 12, 2007 3:25 pm
You may want to try a blacksmith or metalworking shop. The strength properties of metals are affected by heating and cooling. I don't know what the effect on bronze is, but if you were to heat up steel in order to bend it, and didn't retemper it, you would lose strength.
I have the same problem with my handle, which is actually slightly twisted where it goes through the centerboard. I'm going to try and locate a blacksmith and have him re-square the dowel and make a matching insert to mount on the new foil.
Regards,
Wyatt
DS1 2922
Wyatt
Users browsing this forum: Google [Bot] and 13 guests
