Compatibility between ds 1 and ds 2
Postby PassingWind » Mon Jun 25, 2012 2:54 pm
It appears that the rudder and tiller are the same and possibily the sails. How about the mast and boom and the center board?
PassingWind
Postby GreenLake » Mon Jun 25, 2012 2:57 pm
The CB for the DS2 is different, it uses cables and not a lever.
Postby PassingWind » Mon Jun 25, 2012 3:04 pm
GreenLake wrote:The CB for the DS2 is different, it uses cables and not a lever.
Thanks. So the sails,mast,boom,Rudder should all be good for the ds1
PassingWind
Postby jeadstx » Mon Jun 25, 2012 3:13 pm
I have a DS1 mast on my DS2.
Postby GreenLake » Mon Jun 25, 2012 5:00 pm
Just make sure if you get a mast that you get the correct one (keel-stepped vs. tabernacle). That's not DS1 vs DS2 specific.
And mast and boom need to go together - I believe having read that there is some differences in gooseneck fittings over time. (Worst, you'd need a new fitting).
Postby Kleanbore » Mon Jun 25, 2012 6:17 pm
The DS2 mast is 6" shorter than the DS1 due to the raised floor in the cuddy. Accordingly, you can shorten a DS1 mast for use on a DS2.
Kerry Klingborg
74 O'Day DSII
Sail #7182
Kleanbore
Postby jeadstx » Tue Jun 26, 2012 11:37 am
My DS2 boom has no problems with my DS1 mast. The 6" difference Kerry mentioned does explain why the head of my sail does not go all the way up.
