Compatibility between ds 1 and ds 2
Postby PassingWind » Mon Jun 25, 2012 2:54 pm
It appears that the rudder and tiller are the same and possibily the sails. How about the mast and boom and the center board?
PassingWind
Postby GreenLake » Mon Jun 25, 2012 2:57 pm
The CB for the DS2 is different, it uses cables and not a lever.
Postby PassingWind » Mon Jun 25, 2012 3:04 pm
GreenLake wrote:The CB for the DS2 is different, it uses cables and not a lever.
Thanks. So the sails,mast,boom,Rudder should all be good for the ds1
PassingWind
Postby jeadstx » Mon Jun 25, 2012 3:13 pm
I have a DS1 mast on my DS2.
Postby GreenLake » Mon Jun 25, 2012 5:00 pm
Just make sure if you get a mast that you get the correct one (keel-stepped vs. tabernacle). That's not DS1 vs DS2 specific.
And mast and boom need to go together - I believe having read that there is some differences in gooseneck fittings over time. (Worst, you'd need a new fitting).
Postby Kleanbore » Mon Jun 25, 2012 6:17 pm
The DS2 mast is 6" shorter than the DS1 due to the raised floor in the cuddy. Accordingly, you can shorten a DS1 mast for use on a DS2.
Kerry Klingborg
74 O'Day DSII
Sail #7182
Kleanbore
Postby jeadstx » Tue Jun 26, 2012 11:37 am
My DS2 boom has no problems with my DS1 mast. The 6" difference Kerry mentioned does explain why the head of my sail does not go all the way up.
Users browsing this forum: Bing [Bot] and 3 guests
